Date/Time: Sat, 11 Jan 2025 17:44:30 +0000
CQG market depth
View Count: 1332
[2016-12-29 08:52:43] |
Luke - Posts: 142 |
I just switched from AMP/TTnet to AMP/CQG. Is there any way I can change market depth in the trading dom so that it only displays top of the book data? With AMP/TTnet the requested market depth could be adjusted.
[2016-12-29 17:47:52] |
This can be controlled with this setting: http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#MaxDepthLevelsDisplayed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-30 08:18:33] |
User297539 - Posts: 55 |
I changed also by TTnet to CQG and now I market depth of 15. How do I hide the last 5 to to I get market depth of 10?
30-12-2016 09-05-55.jpg / V - Attached On 2016-12-30 08:17:51 UTC - Size: 271.56 KB - 323 views |
[2016-12-30 10:01:26] |
You just need to set this setting to 10: http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#MaxDepthLevelsDisplayed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
