Date/Time: Sat, 20 Jun 2026 17:22:33 +0000
GetExtendedArraySize()
View Count: 1020
| [2016-12-29 03:25:03] |
| b3cker - Posts: 34 |
Hello, Extending bars to the right seems to work for a Subgraph[0] but does the sc.Subgraph[0].Arrays[1] also gets extended to the right at same time automatically? I am using it to store intermittent results. Also is there a limit to number of bars extended to the right? Thank You Gary Becker SCSubgraphRef MAS = sc.Subgraph[0]; SCFloatArrayRef ffpl = sc.Subgraph[0].Arrays[1]; Length.SetInt(135); ForwardCycle.SetInt(Length.GetInt() * 4); MAS.ExtendedArrayElementsToGraph = ForwardCycle.GetInt(); |
| [2016-12-29 16:32:05] |
Does GetExtendedArraySize() returns ExtendedArrayElementsToGraph not ArraySize + ExtendedArrayElementsToGraph? Also it seems ExtendedArrayElementsToGraph is limited to 150 bars. Is it correct? Thank You |
| [2016-12-29 18:33:58] |
Yes.You can increase the number of columns after the last bar with: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#NumForwardColumns GetExtendedArraySize() returns ArraySize + ExtendedArrayElementsToGraph. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
