Date/Time: Sun, 08 Sep 2024 00:19:24 +0000
Alert When Price Crosses the Lower Bollinger Band Line
View Count: 1627
[2013-08-05 19:41:28] |
infpz - Posts: 826 |
Is this accurate? =CROSSOVER(LASTTRADE, SG3) If so, is there a way to set it so that the alert sounds only on the way down, not on the way up? Thanks, |
[2013-08-05 19:53:49] |
Sawtooth - Posts: 4083 |
Try this: =AND(C[-1]>SG3[-1],C<SG3) |
[2013-08-05 19:54:37] |
Thanks!
[2013-08-05 19:55:08] |
If I want the alert right away, not at the bar close, would I still use that formula?
[2013-08-05 20:20:15] |
Yes, but uncheck Evaluate On Bar Close. |
[2015-06-18 21:37:36] |
User147893 - Posts: 10 |
lets take this a step further, i want next alert fired when bar closes above the upper bollinger band, and then the next alert fired when the bar closes below the lower bollinger band and so on... how can i program that... please help!
