Date/Time: Sat, 11 Jan 2025 17:47:33 +0000
Amend attached orders Target & Stops via Spreadsheet for Trading
View Count: 1034
[2016-12-29 02:54:12] |
User553714 - Posts: 184 |
Hi, I am using cells J80 & J81 in the Spreadsheet (SS) for Trading study to set the attached order Target & Stops (instead of the Trade Windows / Twconfig files.) Is there a way for the SS study to amend these orders? I think you can achieve this by using cell J27 to cancel the working orders (once in a position) and then re-submit a new Target & Stop, but I was wondering if you can somehow amend the attached Target & stop instead? (NB: I don't want to do this manually and would like the SS to keep control.) |
[2016-12-29 03:11:43] |
No, this is not supported. To modify an order you need to use ACSIL instead: http://www.sierrachart.com/index.php?page=doc/ACSILTrading.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-29 16:29:23] |
Sawtooth - Posts: 4148 |
You can use the Trade Management by Study study to modify Attached Orders placed by the Spreadsheet System for Trading study's J80/J81. The formula to modify the stop and/or target needs to return a price and needs to be in a Formula Column. Then set the Trade Management by Study's 'Controlling Subgraph Reference' to that spreadsheet's sugbraph. Date Time Of Last Edit: 2016-12-29 16:33:07
[2016-12-29 18:27:33] |
This is a good idea. We had not thought of that.
[2016-12-29 23:35:03] |
SC, Is this ACSIL soure code available for this study, I wasn't able to find anything when searching through the ACS folder study? I can see the study in the list of built in SC studies and will use it from there, but I will be going down the ACSIL route sometime in the NY so any source code will be helpful. NB; thanks Tom for picking this up. |
[2016-12-30 10:18:22] |
The source code is in the file /ACS_Source/AutomatedTradeManagementBySubgraph.cpp provided with Sierra Chart.
