Date/Time: Sat, 11 Jan 2025 19:45:56 +0000
Failed to compile a study.
View Count: 811
[2016-12-28 16:23:38]
Viacheslav Malafeev - Posts: 88
Hi. This started today for no reason. Tried SC versions 1500-1502, but copile result is the same:
1>libcpmtd.lib(stdthrow.obj) : error LNK2019: unresolved external symbol __CrtDbgReportW referenced in function "void __cdecl std::_Debug_message(wchar_t const *,wchar_t const *,unsigned int)" (?_Debug_message@std@@YAXPB_W0I@Z)
1>..\..\..\..\..\..\..\SierraChart\Data\WaveTrend.dll : fatal error LNK1120: 1 unresolved externals
[2016-12-28 18:08:40]
We will need to look into this.
For now use the "Analysis >> Build Custom Studies DLL >> Remote Build" command.
[2017-01-04 17:28:11]
Any news on that? All new studies created in VS fail to compile. I tried to modify one of the older studies and for some time it worked, but now it's giving me the same error.
Looking forward to solution.
[2017-01-04 17:50:11]
We think we may have identified the problem. We will have a new release out today which should solve this.
[2017-01-04 19:08:39]
Update to prerelease version 1505 which we have now released and see if the problem is resolved.
[2017-01-05 00:16:09]
Updated. The problem is not resolved. Error message is the same.
[2017-01-05 00:18:54]
OK then we definitely cannot solve it. We cannot reproduce it either. We simply cannot provide any further help with this. This is out of our control.
You must use the "Remote Build" command. It is going to be much more reliable. You should have no trouble with using that.
[2017-01-06 02:53:16]
After I updated Visual Studio to the next version, it works. Compiler has been updated as well. Maybe this will help other users.
