Date/Time: Sat, 11 Jan 2025 17:48:44 +0000
TPO
View Count: 615
[2016-12-27 16:54:23] |
User479525 - Posts: 22 |
I am new to TPO can someone offer me some settings or template form that has worked for them. Thank You very much for any help
[2016-12-27 18:31:23] |
Not sure you are really going to get the kind of answer you are looking for from a user. Everyone has their own method of using TPO Profile Charts. You really have to understand these types of charts. The default configuration of the TPO Profile Chart Study is a good one to start with. Here is the relevant documentation: http://www.sierrachart.com/index.php?page=doc/TPOVolProfileCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
