Date/Time: Sat, 11 Jan 2025 17:51:26 +0000
RTH Session Open and Close Marker
View Count: 1117
[2016-12-27 14:39:01] |
User24187 - Posts: 54 |
Is it possible to have some kind of a marker that would indicate RTH open and close markers on a 24 hr CVB chart?
[2016-12-27 18:53:39] |
Yes. This can be done with the Vertical Grid: http://www.sierrachart.com/index.php?page=doc/ChartMenu.html#VerticalGrid Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
