Date/Time: Sat, 11 Jan 2025 17:43:01 +0000
chartbook locking
View Count: 736
[2016-12-27 12:02:46] |
User30743 - Posts: 365 |
is is possible to lock a chartbook in a way that only people with specific password could use it (similar to the way the custom studies work)
[2016-12-27 18:47:47] |
No, this is not supported.
