Date/Time: Sat, 11 Jan 2025 17:49:00 +0000
Diagonal Dominant Side Question
View Count: 1585
[2016-12-27 04:22:07]
User529859 - Posts: 18
Quote from documentation about Diagonal dominant coloring background
"Diagonal Dominant Side is similar except the Bid Volume at one price level is compared diagonally to the Ask Volume at the next higher price level. Due to the diagonal comparison, the Bid Volume and Ask Volume at a single level could both be considered dominant."
so my question is : if both bid and ask has dominant status on single level, how the color will show? show bid or ask?
thanks
Rex.
[2016-12-27 05:14:48]
The Numbers Bar study is an immensely complex study with many configurations. We cannot answer this because we do not know what how Numbers Bars Text or Background Type Inputs are set?
Date Time Of Last Edit: 2016-12-27 06:11:08
[2016-12-27 16:05:38]
column 1 numbers bars text : no text
column 1 background type ABDiff Profile
column 1 Background coloring method Diagonal Dominant Side
enable diagonal zero bid/ask compares Yes
[2016-12-27 19:16:42]
You cannot use that Background Type. It is not going to give you the colors that you need to see when using Diagonal Dominant Side for the Column # Background Coloring Method.
Refer to the description at #8 here:
http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#BackgroundColoringMethods
The documentation states:
Column # Background Type must be set to Background on Dominant Side.
Date Time Of Last Edit: 2016-12-27 19:17:12
