Date/Time: Sat, 11 Jan 2025 17:57:03 +0000
Pullback Colume
View Count: 749
[2016-12-27 02:59:42]
Rino - Posts: 124
If you choose Candlestick Body Fill, it
colors in the Pullback Column as well. Even if you choose
None-transparent for it.
Thanks as always,
PS At least I can not get it to stop :oP
PSS If anyone is wondering how I got the candle to look like that.
I used two instances of numbers bars. One with Candle fill
and one candle outline.
Date Time Of Last Edit: 2016-12-27 03:00:54
image1.jpg / V - Attached On 2016-12-27 02:57:32 UTC - Size: 184.61 KB - 264 views
[2016-12-27 09:40:56]
This will be solved in the next release. A candlestick should not be drawn for the Pullback Column.
