Date/Time: Sat, 11 Jan 2025 17:49:47 +0000
Volume by Price
View Count: 869
[2016-12-27 02:55:31] |
User488039 - Posts: 114 |
1) Is there a way to show a larger profile to the right, where it doesn't overlap the daily profiles? (Please see attached 1). I read about this, and I have it set to not overlap, but it still does. 2) Please disregard Attached 2, I figured this out. 3) When it comes to the Dom, is there a way to have Studies loaded on the right, rather than the left side? Thanks Date Time Of Last Edit: 2016-12-27 04:22:15
Attached 1.png / V - Attached On 2016-12-27 02:55:06 UTC - Size: 342.85 KB - 240 views Attached 2.png / V - Attached On 2016-12-27 02:55:14 UTC - Size: 167.84 KB - 272 views |
[2016-12-27 07:55:43] |
Please Disregard Above. 1) Please disregard Attached 1. I figured it out. "Maximum Volume Bar Width Percentage 1" 2) Please disregard Attached 2. I figured this out. 3) When it comes to the Dom, is there a way to have Studies loaded on the right, rather than the left side? Thanks |
[2016-12-27 18:33:41] |
1. This is the relevant Input setting to use: http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_AllowSideBySideProfilesRSide 3. No. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
