Date/Time: Sat, 11 Jan 2025 17:35:29 +0000
PnF Bar Type based on Different Time Interval Closes/Last Price
View Count: 674
[2016-12-26 20:16:50] |
User68474 - Posts: 201 |
Is it possible to create Point and Figure Bar Type Charts based on, let's say, 1,5 or 60 minute closing price(last) data? I know this might sound naïve (it is not) in that, by definition, PnF is not "time-based". I would want to only use those fixed, time-based closing prices as the data to determine reversal conditions based on the already determined box size and reversal amounts.
[2016-12-26 22:25:51] |
This can be done by using the Point and Figure Study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s140 Refer to the detailed documentation about this. You will also want to set the Calculate Only Using Close Prices Input to Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
