Date/Time: Sat, 11 Jan 2025 17:55:01 +0000
scsf_DynamicMemoryAllocationExample does not compile
View Count: 834
[2016-12-26 14:48:35]
b3cker - Posts: 34
Web help example scsf_DynamicMemoryAllocationExample does not compile (MV C++) in otherwise compliable project.
Thank You
[2016-12-26 17:32:30]
We tested compiling this function using the "Remote Build" command and it did compile without issue. Not sure what problem you are having with Visual C++.
This is what we tried compiling:
SCSFExport scsf_DynamicMemoryAllocationExample(SCStudyInterfaceRef sc)
  if (sc.SetDefaults)
    // Set the configuration and defaults
    sc.GraphName = "Dynamic Memory Allocation Example";
    sc.AutoLoop = 0;
    sc.FreeDLL = 0;
    return;
  // Do data processing
  double * p_DoubleArray = (double*)sc.GetPersistentPointer(1);
  if(sc.LastCallToFunction)
    if(p_DoubleArray != NULL)
      sc.FreeMemory( p_DoubleArray);
      sc.SetPersistentPointer(1, NULL);
    return;
  if(p_DoubleArray == NULL)
    //Allocate an array of 1024 doubles.
    p_DoubleArray = (double *) sc.AllocateMemory( 1024 * sizeof(double) );
      sc.SetPersistentPointer(1, p_DoubleArray);
    else
      return;
  //assign value to one of the elements
  p_DoubleArray[0] = 100;
  return;
