Date/Time: Sat, 11 Jan 2025 17:34:52 +0000
Custom Array - Repeat open n bars
View Count: 1184
[2016-12-26 04:43:12]
jakesans - Posts: 50
Hi SC-
Doubtful possible with Spreadsheet study, but if use ACSIL Custom Study how do I create the following array?
E.g.
Open bar0 = 53.23 - replace to 53.22
Open bar-1 = 53.27 - replace to 53.22
Open bar-2 = 53.22
Open bar-3 = 53.24 - replace to 53.23
Open bar-4 = 53.23 - replace to 53.23
Open bar-5 = 53.23
Open bar-6 = 53.18 - replace to 53.19
Open bar-7 = 53.17 - replace to 53.19
Open bar-8 = 53.19
Output Array {53.22,53.22,53.22,53.23,53.23,53.23,53.19,53.19,53.19}
Thx, Jake
Date Time Of Last Edit: 2016-12-26 04:43:37
[2016-12-26 17:34:08]
If you are using ACSIL, here is the relevant reference for arrays:
http://www.cplusplus.com/doc/tutorial/arrays/
You can also use one of the Arrays on a sc.Subgraph:
ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].Arrays[][]
