Date/Time: Sat, 11 Jan 2025 17:38:07 +0000
Trade Activity Log > Trade Statistics > Copy/Paste not working
View Count: 889
[2016-12-26 03:40:18] |
User553714 - Posts: 184 |
The copy & paste function for - Trade Activity Log > Trade Statistics > doesn't seem to be working only the copy all option. The copy paste works for the other sheets in the Trade Activity log like "Trade Activity" & "Trades" but not for the "Trade Statistics" which is the one I like copying the "all trades" column and keep as a record while testing system alternatives. Can you please correct this or am I missing something? |
[2016-12-26 04:06:18] |
To further clarify, the "copy selection" doesn't work and it's also greyed out for "Trade Statistics", the "copy all" still works which is what I have been using although the copy selection for the "Trade Statistics" sheet would be much more convenient. The "copy selection" works for the other sheets as stated in my 1st post.
[2016-12-26 04:32:12] |
Yes this is true. Only Copy All will work.
[2016-12-27 01:21:37] |
Ok. If this is a feature that can easily be added can you please consider doing so in a future release? This is not urgent at all. Also, the vertical graphics delineator on the LHS of the active sheet tab of the "Trade Activity log" window always disappears when you cycle through the tab sheets, the delineator only appears on the RHS of the active sheet; it makes it a little difficult knowing which is the active sheet. |
[2016-12-27 02:02:32] |
There is zero consideration of this. This is very involved and you would not see it for years anyway. We do not clearly understand this and we do not see any kind of behavior like this: Also, the vertical graphics delineator on the LHS of the active sheet tab of the "Trade Activity log" window always disappears when you cycle through the tab sheets, the delineator only appears on the RHS of the active sheet; it makes it a little difficult knowing which is the active sheet. Being we cannot duplicate it, we probably cannot do anything about it anyway. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-27 02:11:40
[2016-12-27 02:11:49] |
The prior post has been updated.
