Date/Time: Sat, 11 Jan 2025 17:32:09 +0000
Sierra Chart's Version of Bookmap
View Count: 5491
[2016-12-26 01:57:07] |
User488039 - Posts: 114 |
Hi, Can you tell me if Sierra's Engineers have completed their version of a Bookmap study? Thanks |
[2016-12-26 02:03:42] |
Yes. This has been out for several months now. Here is the documentation: https://www.sierrachart.com/index.php?page=doc/MarketDepthHistoricalGraph.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-26 02:19:40] |
I'm following the instructions for the Global Settings >> Symbol Settings. I trade the NQ, can you tell me what symbol pattern I should use? Also, once I have this setup, will I see the indicator on my chart when the market is closed? Thanks Date Time Of Last Edit: 2016-12-26 02:56:27
[2016-12-26 02:52:29] |
NQ?# in the case of when using Transact. For historical market depth data, it has to be captured in real-time. You should not expect to see anything at this time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-26 03:27:10] |
I have one final question. I'm a bit confused with the following... "To display lines on the chart at the most recent Bid and Ask prices at each chart bar, use the Bid and Ask Prices study". Is this needed for the Market Depth Historical Graph to work, or is it independent of the study? Lastly, I want to thank all of you Engineers that created this, what an incredible thing to do. |
[2016-12-26 17:42:38] |
No, that study is not needed.
