Date/Time: Sat, 11 Jan 2025 17:45:35 +0000
Sierra with Interactive brokers.
View Count: 779
[2016-12-24 15:03:35] |
User936204 - Posts: 6 |
Can I use the Sierra Chart with Advanced Features pack connected to my own data provider which is IB? If so, can I trade directly from Sierra charts? or should I still trading through IB platform? |
[2016-12-24 20:35:44] |
Yes Interactive Brokers is supported and trading from Sierra Chart is supported using Interactive Brokers.
