Date/Time: Sat, 11 Jan 2025 17:53:03 +0000
issue w/ new DLL Sierrachart/Studies
View Count: 812
[2016-12-24 02:09:36]
jizzary - Posts: 177
Hi
i have generated a 32 bit DLL w/ a single study
when loading the DLL to the studies window at the Sierrachart platform
it shows the single study twice
i have checked the DLL using an independent took (called DLL Export Viewer)
and see very clear that the study appears only once in the DLL
so the question is why Sierrachart presents it twice ?
pls assist me on that issue. tnx
Private File
Private File
[2016-12-24 02:18:13]
thinking loudly ...
the DLL is compiled w/ DEBUG INFO
can the DEBUG INFO PRESENCE cause the above reported issue ?
[2016-12-24 02:24:19]
pls do not put time on this issue
after dropping the debug info the issue has gone
no problem any more
[2016-12-24 02:29:31]
sorry (i had a mistake) - the issue is still present
pls refer this topic as valid
i'm attaching the DLL file
Private File
[2016-12-24 05:34:13]
We see the problem. This is harmless, but we will solve this in the next release.
The function name shows up twice in the DLL with a slightly different variation.
[2016-12-24 09:50:36]
great ... when can i expect the next release pls ?
[2016-12-24 10:49:03]
In about two days.
