Date/Time: Sat, 11 Jan 2025 17:44:35 +0000
return to ray and alert crossing sound time
View Count: 679
[2016-12-23 21:06:29] |
User472677 - Posts: 356 |
1. After another tool use, I want it to auto return to ray. how? 2. on ray I have default alert sound on crossing. I want to set the time how long sound plays and also to acknowledge it to shut it off. hoe? |
[2016-12-26 17:54:29] |
1. This will be supported in the next release of Sierra Chart. 2. The only way to control this is to set the number of times the alert sound is played. Refer to: https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#AlertSoundSettings There is no way to stop it early. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
