Date/Time: Mon, 16 Sep 2024 19:06:43 +0000
current version
View Count: 1412
[2013-08-05 14:48:45] |
rccvelo - Posts: 18 |
Hi. I am currently using version 997. Am I supposed to be using version 1004, which is Pre-release, or use 997 which is current version? Thank you. Date Time Of Last Edit: 2013-08-05 16:23:40
[2013-08-05 16:14:45] |
Sierra Chart - Max - Posts: 5662 |
In most cases you would want to stay with the current version.
Sierra Chart Support Date Time Of Last Edit: 2013-08-05 16:15:10
[2013-08-05 16:23:14] |
For now just stay with the current version.
