Date/Time: Sat, 11 Jan 2025 17:57:58 +0000
Accessing study value programmatically before the bar closes
View Count: 753
[2016-12-23 17:31:20]
User65279 - Posts: 6
Using "Write Bar and Study Data To File" Study, I can write chart data to file on bar close.
But is it possible access chart data for the current bar programatically (e.g. write to file so that other application can use it) before it closes? E.g. I have moving average study and I would like to know programatically what the current value is, even though the bar is not yet closed.
Thank you.
[2016-12-23 18:36:02]
Yes the ACSIL function can certainly access the current bar data. This is very basic. Refer to:
http://www.sierrachart.com/index.php?page=doc/ACS_ArraysAndLooping.html
As far as writing that to the file, that is your responsibility to determine how to do that. It is complex to update the last line in the file as the last bar changes.
Date Time Of Last Edit: 2016-12-23 18:36:52
[2017-01-01 21:22:55]
Thank you.
Date Time Of Last Edit: 2017-01-01 21:59:38
[2017-01-01 21:52:51]
Please do not say thank you.
