Date/Time: Sat, 11 Jan 2025 17:51:20 +0000
windows error 193 while trying to load DLL
View Count: 923
[2016-12-23 01:18:04]
jizzary - Posts: 177
Hi
after searching the web i came to conclusion that the issue arised as Sierra is 32 bit application while i'm creating a 64 bit DLL
do u know the setting to compiler/linker to force a 32 bit DLL creation ?
tnx
[2016-12-23 01:28:21]
in order to build the 32 bit DLL (to successfully be loaded w/ Sierra) i will need a 32 bit C run time
have a URL where to get it ? or should i install a 32 bit version of MinGW ?
[2016-12-23 01:49:15]
There is nothing special you need to do to create a 32-bit DLL for Sierra Chart using the built-in build system through Analysis >> Build Custom Studies DLL.
This all happens automatically.
If you need to do the build/compile outside of Sierra Chart, then this is your responsibility to understand how to create a 32-bit DLL. Certainly Visual C++ can support this.
