Date/Time: Sat, 11 Jan 2025 17:45:42 +0000
Ray preset to always havbe alert
View Count: 711
[2016-12-22 19:37:03] |
User472677 - Posts: 356 |
How to set a ray so that when it is drawn, it automatically has alert enabled for crossover and sound? Manually adding alert and having to set properties of alert each time is VERY DESTRUCTIVE TO ACTIVE TRADING AS THE PROCESS INVOLVING NUMEROUS CLICKS DISTRACTS FROM THE TRADE. |
[2016-12-22 22:12:05] |
How to do this is explained here: Chart Drawing Tools: Configuring a Default Chart Drawing Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
