Date/Time: Sat, 11 Jan 2025 17:44:12 +0000
Order went tho and vanished
View Count: 674
[2016-12-22 18:50:09] |
User638756 - Posts: 52 |
Hi, I put in a order though the DOM and it executed and then vanished. Trade Activity Log: File read result: 11749 records inserted. 0 records filtered. | 2016-12-22 18:24:55 Trade Activity Log: File date-time limits: Sim records date-time limit is 2016-12-07 00:00:00. Non-sim records date-time limit is 2016-09-20 00:00:00. Non-sim fill record date-time limit is 2015-12-23 00:00:00. | 2016-12-22 18:24:55 Interactive Brokers | Requesting Open orders. | 2016-12-22 18:25:12 Interactive Brokers | Received Open orders end message. | 2016-12-22 18:25:12 Trading message from IB: Order Event Warning:Attribute 'Outside Regular Trading Hours' is ignored based on the order type and destination. PlaceOrder is now being processed. Error Code: 2109. ServiceOrderID: 453. | 2016-12-22 18:26:23 Trading message from IB: Order Event Warning:Attribute 'Outside Regular Trading Hours' is ignored based on the order type and destination. PlaceOrder is now being processed. Error Code: 2109. ServiceOrderID: 456. | 2016-12-22 18:26:23 Trading message from IB: Order Event Warning:Attribute 'Outside Regular Trading Hours' is ignored based on the order type and destination. PlaceOrder is now being processed. Error Code: 2109. ServiceOrderID: 459. | 2016-12-22 18:26:23 Interactive Brokers | Requesting Open orders. | 2016-12-22 18:26:47 Interactive Brokers | Received Open orders end message. | 2016-12-22 18:26:48 Interactive Brokers | Requesting Open orders. | 2016-12-22 18:27:48 Interactive Brokers | Received Open orders end message. | 2016-12-22 18:27:48 Interactive Brokers | Requesting Open orders. | 2016-12-22 18:30:50 Interactive Brokers | Received Open orders end message. | 2016-12-22 18:30:50 |
[2016-12-22 19:33:53] |
What you are referring to is the Trade Position is not being properly reported by Interactive Brokers Trader Workstation. This is explained here: http://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#TradePositionLineQuantityDisappearingDisplayingZero Was this for a stock, futures contract or Forex market? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-22 19:34:49
[2016-12-22 19:38:12] |
It was for a stock, I just downloaded thanks again Sierra!
[2016-12-22 21:39:05] |
What is the exact symbol? There might be a problem symbol matching although unlikely. We do not think the update is going to make any difference. As a last resort enable the Order Fill Calculated Position for the chart: http://www.sierrachart.com/index.php?page=doc/TradeStatusWindows.html#OrderFillCalculatedPosition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-22 22:59:29] |
SDS, Is there a way you can let me know?
[2016-12-22 23:21:21] |
With a simple stock symbol like that, there will not be a problem with symbol matching related to Trade Positions. And there should not be in any case anyway but we just wanted to see if there was anything unexpected. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
