Date/Time: Sat, 11 Jan 2025 20:01:35 +0000
TPO covering Volume Text...
View Count: 716
[2016-12-22 16:27:49] |
User275302 - Posts: 52 |
Is there a way to push the contract size further over to the right so the TPO's aren't covering them in some places? Thanks.
Volume Text Covered.JPG / V - Attached On 2016-12-22 16:27:32 UTC - Size: 48.33 KB - 232 views |
[2016-12-22 18:20:43] |
Set this TPO Profile Chart study Input to a larger number than 100: http://www.sierrachart.com/index.php?page=doc/TPOVolProfileCharts.html#PercentWidthForVolumeProfile Try 150. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-23 02:10:37] |
[2017-01-07 15:58:02] |
User169041 - Posts: 7 |
Would be nice to put that volume on the left side of the TPO instead on the right side. Can that be done? Thank you Johnny |
[2017-01-07 22:24:04] |
The Volume Profiles can either be in the same column as the TPO Profile or to the right of it.
