Date/Time: Sat, 11 Jan 2025 17:46:54 +0000
Possible bug? When enable full session chart, a new bar is base on UES time
View Count: 1464
[2016-12-22 16:26:54]
User269983 - Posts: 31
I don't know if it is by design or a possible bug.
When have full session enable, the bar on evening session being on the start of the evening time.
I use CL as example where the day session is 9:00:00 to 14:29:29. The hour bar is base on the hour (from 9:00:00 to 9:59:59) when using day session only. However, when evening session is shown, the hourly bar start from the on half hour (example: 9:30:00 to 10:29:29).
When "New Bar At Session Start" is selected, the day session bar is correct, but on the evening session, the bar start at the half hour.
I think if "New Bar at session start" is not selected, it should go from hour being to hour end for all day.
[2016-12-22 18:40:22]
This is normal and is documented here:
http://www.sierrachart.com/index.php?page=doc/SessionTimes.php#BarStartingTimes
What you need to do is to make sure the evening start time is aligned to the base of an hour rather than to a half hour.
