Date/Time: Sat, 11 Jan 2025 17:46:18 +0000
Camarilla Pivot Point
View Count: 4012
[2016-12-22 15:22:53]
User26753 - Posts: 43
How can I import Camarilla Pivot Point into my charts?
[2016-12-22 18:02:03]
The first step is to add one of the Pivot Points studies to the chart:
http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#AddingModifyingStudies
The Camarilla Pivot Points are determined by Formula Type 5, as explained here:
http://www.sierrachart.com/index.php?page=doc/PivotPoints.html#Formula_5
To get these Pivot Point lines in either the Pivot Points – Daily or Pivot Points – Variable Period studies, you need to set the value of the Formula Type Input to 5 in the Settings window for the study. Refer to:
http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#SettingsandInputsTab
[2016-12-22 19:01:30]
Sorry but I find very difficult to build this indicator. Could you please suggest me someone that could help me?
[2016-12-22 19:30:41]
We have attached a Study Collection configured as you require. You will see a link for it below.
Follow the instructions here to use it:
http://www.sierrachart.com/index.php?page=doc/UsingAdvancedCustomStudies.php#UsingStudyCollection
attachmentPivot Points Formula 5.StdyCollct - Attached On 2016-12-22 19:28:51 UTC - Size: 9.4 KB - 644 views
[2016-12-22 19:55:48]
Thanks a lot
