Date/Time: Sat, 11 Jan 2025 17:53:37 +0000
Delta Divergence
View Count: 3514
[2016-12-22 14:04:35]
User713850 - Posts: 33
http://www.sierrachart.com/image.php?Image=1482415139821.png
I am curious why the green arrows did not come up for delta divergence in the highlighted rectangle box shown on the picture? If you look to the right you will see a string of green up arrows, can you please explain to me why this is showing up this way?
Thanks.
[2016-12-22 18:12:24]
We are not sure what study you are using. But the proper study to use is the Divergence Detector study which is fully documented here:
http://www.sierrachart.com/index.php?page=doc/StudiesReference_DivergenceDetector.php
[2016-12-22 18:39:21]
ok i was using cum delta buy/sell volume and cum delta uptick downtick hence no signal in comparison to the lower cum delta bar subgraph. this probably is the reason why i should be using the divergence detector instead of this.
Thanks.
