Date/Time: Sat, 11 Jan 2025 17:42:41 +0000
Duplicate DOM - different columns for different DOMS?
View Count: 813
[2016-12-22 11:26:03] |
User305145 - Posts: 38 |
Hi, When I duplicate a DOM and change the columns - they change for both. Is it possible to have multiple DOMS with different columns? /Martin |
[2016-12-22 11:41:51] |
No this is not supported.
