Date/Time: Sat, 11 Jan 2025 17:56:35 +0000
user discussion; speedy order placement
View Count: 986
[2016-12-22 04:18:37] |
Willson - Posts: 176 |
I am slow typer. Have been using Mkt orders. Now want to use Limit and stop-limit orders. Have been using chart entry. To use limit orders is slow for me. Right click, then find order type, then click. Would DOM be faster, What are speedy methods used by good traders? Use short-cut keys for type of order? Then where to type in entry price. I know question is vague, just looking for best practices. Regards |
[2016-12-22 04:54:12] |
You can use the Chart DOM: https://www.sierrachart.com/index.php?page=doc/ChartTrading.html#ChartDOM You can also use keyboard shortcuts which will also set the price as well: Basic Trading and the Trade Window: Custom Trading Keyboard Shortcuts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
