Date/Time: Sat, 11 Jan 2025 17:44:37 +0000
QuoteBoard
View Count: 680
[2016-12-21 17:16:47] |
Rino - Posts: 124 |
Hi, My QuoteBoard has been showing two days ago Settlement price instead of yesterdays. I think it has been doing it for the last couple of days. Is that a Sierra issue or a data provider one? Thanks as always. PS I opened a new one to make sure and got the same thing. Nationally the DlyChange and such reflects that settlement. |
[2016-12-21 18:10:17] |
This is a data feed issue. Follow the instructions here to reconnect to the data feed: http://www.sierrachart.com/index.php?page=doc/FileMenu.html#ProcedureToReconnect For the best data feed, use the Sierra Chart Exchange Data Feed: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
