Date/Time: Sat, 11 Jan 2025 17:35:44 +0000
large volume trade indicator ?
View Count: 2810
[2016-12-21 03:08:44] |
zippyzip - Posts: 293 |
i noticed you wrote completed on 1500 notes , i thought we talked about having circles with different sizes for different size volume with faded background ? so this round circle is there there is a large volume of more then 500 dominant on the ASK vol and i sent the same on the large volume trade indicator , and it only plots 1 when there is clearly more on the ES at the close |
Attachment Deleted. Private File |
[2016-12-21 04:19:58] |
We will consider a circle draw style and different sizes based on volume, later. There is a variation in color based on the amount of volume. Refer to this video: Videos | Post: 106198 so this round circle is there there is a large volume of more then 500 dominant on the ASK vol and i sent the same on the large volume trade indicator , and it only plots 1 when there is clearly more on the ES at the close
The study does work properly. Refer to the video for how it works: Videos | Post: 106198 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-21 14:02:45] |
disregard
Date Time Of Last Edit: 2016-12-21 16:01:14
[2016-12-21 15:49:04] |
Adam - Posts: 141 |
I would agree with User322949 I'm having the same issue. Could you advise? Adam |
[2016-12-21 17:18:09] |
What issue is that? You can see our response. Restate your problem very clearly for us and how you are coming to that conclusion. Also when posting an image of the chart, follow this method and no other: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-21 17:18:26
[2016-12-21 18:44:17] |
not sure how to get into it , as we are getting different large order values from cme and platform , so let me see if we can come up with a valid response for you
[2016-12-21 18:49:44] |
For a 100 percent accurate data feed use the Sierra Chart Exchange Data Feed: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php You also need to be aware that with most data feeds and also including the Sierra Chart Exchange Data Feed, a large order which matches with multiple smaller orders, is going to be reported as multiple small trades. The capability to re-bundle the trades will come later on and only with the Sierra Chart Exchange Data Feed. We will not support this with any other service because of the complexity of it. More information about this is here: http://www.sierrachart.com/index.php?page=doc/ChartDataFiles.html#LargeVolumeTrades So there is nothing we can do to change the results that you see. They are what they are. So it is unlikely we can provide any additional help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-21 18:50:22
[2016-12-22 01:40:27] |
Neo - Posts: 198 |
Are you going to add subgraphs to the study so that simple alerts can be created?
[2016-12-22 04:09:57] |
Yes we can easily do this. We will do that.
[2016-12-22 08:59:37] |
Adam - Posts: 141 |
Thanks for the clarification on this. What's the timeframe on this? "The capability to re-bundle the trades will come later on and only with the Sierra Chart Exchange Data Feed. We will not support this with any other service because of the complexity of it." I have been waiting for MBO to move to your data but this would trigger me to move immediately Adam |
[2016-12-22 10:13:17] |
All that we can say is that this is a significant development task and it will be sometime in 2017.
