Date/Time: Sat, 11 Jan 2025 23:03:17 +0000
Prior Murray Math Indicator
View Count: 2166
[2016-12-20 16:47:18]
User69055 - Posts: 23
Infinity AT Rep updated my Sierra Charts and I observed after that the indicator: Murray Math version which I use to use
was changed. Before I was able to insert the Square Width now apparently I have to use the values in a drop down. Is
there any way to get the older version uploaded into the "Add Custom Study", User Contributed Studies region?
Thanks!
[2016-12-20 18:55:57]
The Murray Math study was changed to use the standard Square Width values.
Did you want to use something specific or just whatever you want?
We could allow for the study to input a custom width.
[2016-12-20 18:56:41]
The study can be modified. Refer to:
http://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html
[2016-12-29 15:36:55]
Hello! Thanks for the reply. Yes, I would like to be able to insert my own value into the Murray Math Line indicator, if that is not too much of an issue. Thanks again!
[2016-12-29 18:12:36]
This can be now done. There is a new Input with the Murray Math study to support this.
Follow the instructions here to update:
http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
[2017-01-12 17:19:29]
Hello again!
I wonder if there is any way you gents can perhaps upload the older version of Murray Math Line indicator to the Custom Study section.
Thanks guys!
[2017-01-12 17:58:00]
Why do you need that?
