Date/Time: Sat, 11 Jan 2025 14:36:30 +0000
How to choose HLC Avg line on overlay study
View Count: 1482
[2016-12-20 15:58:03] |
jackbravo - Posts: 69 |
Hi, I've use the Overlay study to overlay the main price graph from TICK-NYSE (1min) to ES (5min) chart. I'm trying to change the display under Subgraphs to HLC Avg, but whenever I change it to visible, the choice goes back to Ignore after I hit apply. I've tried different combinations of bars and lines, to allow me to display just a line on HLC Avg. I have been able to use Graph Draw type to display just a HL average, but there is no option under that dropdown to display HLC average. Thanks for your help. Date Time Of Last Edit: 2016-12-20 15:59:06
HLC Avg line.PNG / V - Attached On 2016-12-20 15:58:58 UTC - Size: 131.33 KB - 245 views |
[2016-12-20 18:32:34] |
You need to use the Overlay (Single Line) study instead. And through the Input Data input you can select the particular average that you want.
