Date/Time: Sat, 11 Jan 2025 14:52:43 +0000
How to change exit rules during a trade?
View Count: 1354
[2016-12-20 15:01:54]
Maurice - Posts: 7
I have two different exit rules. The first is a bracket order that is sent when entering a trade.
If price action goes the way I thought, everything is fine and I don't have to close the position manually.
But if conditions change during the trade, I might have to delete the current bracket orders and activate the second exit rule.
So how can I delete all current bracket orders that belong to exit rule #1 and activate exit rule #2?
And is it possible to do this with a click of a button?
Thanks,
Maurice
[2016-12-20 18:12:36]
First step is to make sure both Attached Order configurations are saved:
http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#SavingConfiguration
You need to cancel the Target and Stop orders. Refer to:
http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#TradeDOMModifyingCanceling
You need to then select the particular Attached Order configuration you want to use and then follow the instructions here:
http://www.sierrachart.com/index.php?page=doc/OrderTypes.html#SendAttachedOrders
