Date/Time: Mon, 14 Sep 2026 06:11:22 +0000
How does Tool.DrawingType == DRAWING_LINE work?
View Count: 1414
[2016-12-19 05:58:37]
Edge Player Trading - Posts: 9
The following code draws a line from the starting bar to the last bar of history. However, this code is in a if-block and only gets executed once and there is no code that extends the line. Does the DRAW_LINE work like the DRAW_RAY? If so, is it possible to stop it from extending itself? Thanks.
if (sc.SetDefaults)
  {    sc.GraphName = "Point & Figure Chart";
    sc.AutoLoop = 1; // 0;
    sc.GraphRegion = 0;
    sc.StandardChartHeader = 1;
    sc.ValueFormat = VALUEFORMAT_INHERITED;
    sc.FreeDLL = 1;
s_UseTool Tool;
Tool.DrawingType = DRAWING_LINE;
                           Tool.EndValue = sc.BaseData[SC_POINT_FIGURE_LOW][sc.ArraySize - 1];
   Tool.Color = RGB(0, 0, 255);
   Tool.AddMethod = UTAM_ADD_OR_ADJUST;
   Tool.BeginDateTime = sc.BaseDateTimeIn[sc.Index - 3];
   Tool.EndDateTime = sc.BaseDateTimeIn[sc.ArraySize - 1];
   Tool.BeginValue = sc.BaseData[SC_POINT_FIGURE_LOW][sc.Index - 3];
   sc.UseTool(Tool);
[2016-12-19 07:13:15]
No it does not.
If it is extending itself, it means the block of code is running more than once. You would have to see why. The other thing is to specify a different Date-Time other than the last one:
