Date/Time: Sat, 11 Jan 2025 14:49:28 +0000
DOM
View Count: 873
[2016-12-17 21:56:51] |
User672082 - Posts: 62 |
Hi, When using the DOM to place orders, is there a way to have orders displayed on BOTH sides of the price column? For example I would like buy limit orders on left of bid column (which they are) and sell limits orders displayed on the right side of ask column. Is this possible? |
[2016-12-18 02:40:59] |
Yes you can do this. You can customize the columns. This is fully documented here: https://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#ChartDOMColumnDescriptions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-18 11:42:45] |
Thank you, but I cannot find the info I need in there. Attached is a pic, this is a sell limit order. I would like to move the columns to the center of the DOM so that my orders on the sell limit side, display on the right side of the red ask column, not to the left of the blue bid column. I would like to move the bid/price/ask columns to the center of the dom. Sorry if I missed it in the board, but all I find is the formatting options for the text, etc, not actually moving the entire columns around. http://www.sierrachart.com/image.php?Image=1482061293870.png |
Private File |
[2016-12-18 20:16:43] |
If you want to move the order lines themselves to the right of the price values column, this is not supported at this time. We are not sure if and when we would get to this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-19 12:38:06] |
Ok...is there anyway to move the actual columns themselves to the center of the dom or are they stuck off to the right?
