Date/Time: Sat, 11 Jan 2025 14:41:44 +0000
TPO Extend Singles Study - only solid lines enabled
View Count: 1051
[2016-12-17 19:57:40] |
User693244 - Posts: 1 |
I am using the TPO Extend Singles Study and attempting to set the line to display a dash. However it always remains at a solid setting. Is there any way I can make the dash setting for the Extend Singles study work? Thank you. |
[2016-12-18 02:42:36] |
We will look into this.
