Date/Time: Sat, 11 Jan 2025 14:56:30 +0000
bid x ask chart
View Count: 786
[2016-12-17 00:27:31] |
User839093 - Posts: 5 |
I watch a 5 min BxA chart. can I have a candlestick OHLC bar to the left of each BxA bar ??
[2016-12-17 05:13:49] |
Are you referring to using the Numbers Bars study?
[2016-12-17 17:37:25] |
yes where the actual BxA numbers come up. Ex: 37| 981 612| 1810 1854| 210 63|1212 I'd like a candlestick OHLC to the left of each 5 min bar Thx, George |
[2016-12-18 05:16:26] |
You cannot do exactly that but you can display a candlestick around those numbers. Refer to: Numbers Bars: Open and Close Marker Style You need to set this study Input specifically to: Numbers Bars: Candlestick Outline (Candlestick Outline) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-12-18 05:16:59
