Date/Time: Sat, 01 Feb 2025 03:50:29 +0000
integration with sterling trader.
View Count: 1979
[2016-12-16 20:27:25] |
enemyspy - Posts: 306 |
Hi Sierra Chart, Have you considered or will you consider integrating with sterling trader pro using there FIX api. https://www.sterlingtrader.com/products-and-services/platform-features/sterling-trader-fix-api/ |
[2017-01-19 23:41:03] |
tdd2672 - Posts: 61 |
I would like to see this as well.
[2017-01-19 23:58:53] |
very slowly working on it in my spare time.
[2017-01-20 00:04:08] |
The most ideal thing would be if every firm stopped using sterling altogether.
[2019-06-21 08:28:24] |
User261378 - Posts: 2 |
Hello, Any news regarding integration Sierra charts with Sterling Trader using Fix Api? Thank you |
[2019-06-21 15:14:06] |
From our position this is not going to happen. Please look at this new service which is based on Trading Technologies order routing: Sierra Chart / Trading Technologies Futures Order Routing Service Many clearing firms support TT, so there is broad-based coverage including in Europe. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-21 15:14:17
