Date/Time: Sat, 11 Jan 2025 17:43:40 +0000
Zag Calculation
View Count: 1126
[2016-12-15 18:35:55]
markuz - Posts: 90
i have attached a picture of the indicator not calculating the "zag" on a large move. at 8:45, on the pullback i am not getting a "zag" or number generated.
if you view the picture toward the left, all small moves in short timeframes are calculated so why not the portion circled in black?
would appreciate your insight!
imageZag_screen_shot.png / V - Attached On 2016-12-15 18:35:44 UTC - Size: 35.52 KB - 260 views
[2016-12-15 20:57:27]
We will need to get the Chartbook with a single chart containing the study to be able to see the exact settings of the zig zag study.
Here are the instructions to provide it:
http://www.sierrachart.com/index.php?page=doc/PostingInformation.php#ProvidingChartbookSingleChart
[2016-12-15 21:31:13]
markuz - Posts: 90
I attached the .cht file.
the problem was at 11:24 eastern
attachmentsierra support example.cht - Attached On 2016-12-15 21:30:43 UTC - Size: 29.78 KB - 296 views
[2016-12-15 21:47:01]
markuz - Posts: 90
sorry the issue is at 11:24 PST, not eastern.
[2016-12-16 18:14:33]
markuz - Posts: 90
any luck?
[2016-12-16 18:19:59]
Not yet. We need time to look into this and answer the question. Please allow about a week.
We would expect the result to be completely accurate based upon the documented behavior:
http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s133
[2016-12-22 11:01:52]
Are you referring to this highlighted location:
http://www.sierrachart.com/image.php?Image=1482404439495.png
This makes sense according to the description:
http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#ZigzagCalculationMode2
Read through description and specifically note the application of the Number of Bars Required for Reversal Input.
Date Time Of Last Edit: 2016-12-22 11:02:39
