Date/Time: Sat, 11 Jan 2025 14:56:24 +0000
CQG FIX Live Connection: Trading from a sub-instance doesnt work
View Count: 765
[2016-12-15 18:03:14]
User985778 - Posts: 16
Hi SC-Support-Team,
unfortunately I cannot trader via a CQG live connection from a sub instance. I get an error which says I would use the Simulation 1 account?!
Find screenshots attached.
Thanks a lot!
Best,
Christian
imagecqg live order from sub instance doesnt work.png / V - Attached On 2016-12-15 18:02:34 UTC - Size: 9.3 KB - 230 views
imagecqg live order from sub instance doesnt work2.png / V - Attached On 2016-12-15 18:02:38 UTC - Size: 5.09 KB - 238 views
[2016-12-15 18:16:13]
Refer to this section here:
http://www.sierrachart.com/index.php?page=doc/DTCServer.php#UsingCorrectTradeAccount
Date Time Of Last Edit: 2016-12-15 18:16:46
[2016-12-15 18:17:00]
The link given in the prior post originally was not correct. It has been updated to the correct link.
[2016-12-15 18:33:29]
Thanks a lot, I missed that!
