Date/Time: Sat, 11 Jan 2025 14:57:31 +0000
support to draw UseTool drawings in between bars.
View Count: 758
[2016-12-15 15:11:21] |
@sstfrederik - Posts: 404 |
Hi, I would like to draw an DRAWING_RECTANGLEHIGHLIGHT starting form one side of a bar to another. Is there a way to support drawing with an offset of half a bar for the BeginIndex and EndIndex? Thanks for any pointers. Edit. I know I can use subgraphs, but I would like to draw on several pricelevels and I do not know in advance how many pricelevels will be used to draw a rectangle. Frederik Date Time Of Last Edit: 2016-12-15 16:20:43
[2016-12-15 17:12:47] |
No, this is not supported and there are no plans for this.
