Date/Time: Mon, 13 Jan 2025 07:28:40 +0000
[User Discussion] - New Large volume trade indicator
View Count: 2070
[2016-12-15 14:27:08] |
User11942 - Posts: 298 |
Hi SC team, first off, thanks for adding this! Could you add an option to distinguish whether trades happened at bid or ask please? Also it would be nice to have additional drawing options different from a rectangle. Thank you. |
[2016-12-15 17:52:37] |
We will see about this.
[2016-12-15 18:00:53] |
There will be some updates to this study in the next release.
[2016-12-15 20:58:52] |
Rino - Posts: 124 |
Thanks for this. Please see image. |
Snap73.jpg / V - Attached On 2016-12-15 20:58:01 UTC - Size: 36.92 KB - 2220 views |
[2016-12-15 22:24:53] |
@Rino but this is a different study on your pic, isn't it? I see no any changes to Draw mode in the Large volume trade indicator in 1498.
[2016-12-16 04:43:16] |
We have released a new revision of 1498 which finalizes the Large Volume Trade Indicator study. Update to the latest prerelease following the instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate You can now display text or just a rectangle. There is different coloring whether the bid or ask side is dominant. We will consider other draw styles later. Documentation will come shortly. The Large Volume Trade Indicator study is a very advanced study which processes the low-level data to identify large trades. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-18 23:49:26] |
User16876 - Posts: 11 |
Would you consider to add the possibility to combine trades in a same way like in Time&Sales window? I mean combine trades With Same Time and Type / With Same Time and Price / With Same Price and Type. To be able (for example) to have one dot for trades with same price and type, see screenshot for details... |
Tapereconstructed.png / V - Attached On 2017-04-18 23:48:15 UTC - Size: 185.78 KB - 517 views |
[2017-04-19 04:48:58] |
User93757 - Posts: 61 |
Wouldn't it just be easier to have the Volume Color Based upon Delta Percent? Don t know... just saying.. Anyhow, it is very workable with what Sierra currently has... thx,
[2017-04-19 06:57:54] |
binaryduke - Posts: 373 |
Adding 'Extend to Future Intersection' would be a very nice addition if possible. +1 for bid/ask distinguishing |
