Date/Time: Sat, 11 Jan 2025 14:36:14 +0000
Possible bug? Attached Stop order does not move all contracts when entry order is adjusted
View Count: 735
[2016-12-15 14:09:34] |
User269983 - Posts: 31 |
I noticed this a few time. When I place an entry order with multiple targets and then manually adjusted the stop ALL price. Before my entry price is triggered, I adjusted my entry order, however part of the stop order is setback to the default stop. For example, default attached strategy has 2 targets and a 20 tickets stop. When I place an order, say limit sell at 50.50. SC will attached my stop order at 50.30. I then moved the stop to say 50.10. Now, I adjust my limit entry order to 50.40 (it doesn't matter adjust up or down), now stop order is broken in 2 part, one at 50.00 and the other at 50.20. Both should be at 50.00. I have to manually adjust one of the stop to get them both in the same price. Broker is IB and using the latest version of SC |
Private File |
[2016-12-15 14:11:35] |
One of thing: I have the strategy set to GTC, but the attached orders are set to day. Is this correct behavior?
[2016-12-15 18:25:57] |
There appears to be a problem. We are going to look into this today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-15 18:48:22] |
This is now fixed. We are releasing Prerelease version 1498 at this time.
