Date/Time: Sat, 11 Jan 2025 14:50:36 +0000
[Programming Help] - Trading Macro
View Count: 795
[2016-12-15 03:50:31]
toews&kane - Posts: 209
This maybe a crazy idea but it is useful for short time frames
is there a way I can hit a key sequence at t=0 then it will go through a logic operator, ex. if price closes below current tick, sell market?
The sell actually doesn't trigger right away, the keyboard shortcut just initiates the logic evaulation and is on until it is turned off.
Cheers
[2016-12-15 03:51:12]
trading spreadsheet with the formulas would be hard to turn on and off
[2016-12-15 04:10:52]
I took a look at the sell stop bid-2 ticks
but the scenario that the tick makes a high but closes at open, I would be at level 0 per se in relative to where it started, put in the order, now it drops 1 tick that might be the ideal entry in this case.
But sell stop at bid is already at level -1, sell stop at bid -2 would be two ticks down.
