Date/Time: Sat, 11 Jan 2025 14:40:02 +0000
OHLC bars resize
View Count: 863
[2016-12-15 03:37:24]
sellis67 - Posts: 105
is there a way to resize the OHLC bars? can't figure it out. Want to make them thicker
[2016-12-15 04:51:28]
This is done through the Graphics Settings window. Refer to:
Graphics Settings
[2016-12-15 05:15:14]
The change is getting rejected. I'm trying to change the OHLC width to 150% from 75%. When I go back to the settings the number has been returned to 75%. Please advise
[2016-12-15 05:21:36]
Therefore, you are entering an invalid percentage.
You cannot make that particular width greater than 100 percent.
[2016-12-15 05:25:57]
Ok cheers
