Date/Time: Sat, 11 Jan 2025 14:54:30 +0000
Not enabled on package
View Count: 807
[2016-12-15 02:01:35] |
User130418 - Posts: 1 |
Hello I am looking to try a trial with CQG with amp futures and just need the provider enabled it currently says not enabled.
[2016-12-15 02:11:47] |
Your account has been activated and/or reset. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
