Date/Time: Sun, 09 Mar 2025 00:44:26 +0000
Line thru mid point on Price DOM
View Count: 1174
[2016-12-14 21:13:59]
User48838 - Posts: 122
v1496 has a line thru the mid point price of the DOM, 1495, which i rolled back to doesnt.
imagev1496 line thru mid point.png / V - Attached On 2016-12-14 21:13:26 UTC - Size: 2.86 KB - 279 views
[2016-12-14 21:52:51]
Cavalry3162 - Posts: 523
@SC - am excited to see it coming.. its just an alignment issue you should take care off..
@User48838 - you could've disabled it in the graphics setting "Trade DOM Recenter Line"... fwiw..
Andreas
[2016-12-15 02:05:07]
This line can be disabled through the Graphics Settings window:
http://www.sierrachart.com/index.php?page=doc/GraphicsSettings.html
The list on the first tab, select Trade DOM Recenter Line and uncheck the Enable option.
We will make sure it is off by default in the next release.
[2022-02-25 06:49:00]
User769783 - Posts: 191
Is there a way to access this by chart alert study or ASCIL? Thanks
[2022-02-25 16:20:45]
John - SC Support - Posts: 38516
No, this is not accessible anywhere.
[2022-02-25 19:51:26]
Is there a calculation for it? Thanks
