Date/Time: Sat, 11 Jan 2025 14:41:44 +0000
Disable Replay
View Count: 1354
[2016-12-14 14:43:36]
User104854 - Posts: 456
Hi. Is there a way to disable all replays from the chartbook? I am trying to turn trade simulation mode off but I get an error that it can't be turned off while reply is running. I've checked each individual chart and do not see an instance where it is actually running. Thanks.
[2016-12-14 17:15:43]
The easiest way to do this is just to exit from Sierra Chart if you cannot find a particular chart that is replaying.
One thing for certain is if you are getting that message, there is at least one chart replaying in one of the open Chartbooks.
